T.S.U.Filmz
My SRX had a crack in the Primary so i got a good deal on a primary off of a SXR. i switched my heal clicker kit into the clutch and now when i try to run it my belt slips in the the SXR primary. are these different other than the set screws on the roller pins of these clutches?
you need 15.6 roller with HC's,SX clutches usually come with 14.5 mm rollers.
T.S.U.Filmz
the rollers are from the primary that were on the SRX I used them cuz i know they worked. i forget what i have in there i can try different rollers.
