Adam700sxr
After running for a day, the 2nd day the heat indicator will blink 3 times and the engine will cut out for 2 seconds and restart. This is a hit and miss as to when it will happen. Last week the high/low beam switch could not be on low and high worked fine. What's up?
The tech manual says the 3 blinking is the head bulbs. check and all fine. what next? relay? Does anyone think snow dust gets into the light and shorts the head bulb?
