Is there an actual bearing that can be used to replace the roller on clutch?
Yamahasrx700 said:
Thats why I use a HITECH 911 primary cover since new. 10k miles on my 02. Tight as a drum. I had to replace the clutch because the sheves were worn but the bushings are excellant.
ME TOO . I NEEDED ONE ROLLER AT 10K
Listen to Mr Viper rebuild it completely !!! its worth waiting a while to save a little cash so you can fix it right ! Quick fixes Most Always come back to haunt you and cost more in the long run.
