davessrx
It's been awhile since we bought our poos and I do miss my SRX everytime I hit the gas!!! anyhow I have a couple friends machines I am working on and need some help.
1st
sxr 600 triple. Sat for a year or so. Cleaned fuel tank, carbs 3x's, has new fuel filter, lines and pump is now been cleaned out. At idle gas pours out of the #3 carb tubes. Floats were checked and seemed ok when carbs were cleaned. Anything else that can cause this, bad pump...friend did have it apart??? Other than that it runs well.
2nd sled
vmax 700 triple 2001
Blew up #1 cylinder, was just in a couple months ago at local dealer for the tune of $400 to have the carbs cleaned and synched. So why did it blow? machine ran fine then came up to a stop and started to run poor, #1 dead. I will be rebuilding this thing soon and I am thinking that I should do crank seals as well. Machine has 12,000 miles. Also pistons, SPI or OEM, yes the machine has 12,000 miles and the cheaper the better. Anyone with specs on head and crankcase bolts would help a lot. Also other than clutch puller will I need any special tools...looks like PTO crank side seal has a bearing on the outside of it.
1st
2nd sled
