peisnowguy
Hi All
Was there ever a stock piston port 440 with dual carb Keihin diaphram type butterfly carbs? On one of the other forums a guy is trying to get one started that he has in a '77 Exciter. It isn't pumping gas to the carbs. There is no return outlet on the cabs. It only has pulse and gas connections on the carbs. The serial number on the carbs says it is off a 1972 SW 440 I believe. Did this have dual carbs and if so what would the horsepower of such an engine be? Also if anyone has any ideas on getting this beast started andy tips would be appreciated. Oh the cylinders have the number "433cc R" stamped on them.
