have a 2000 sxr that i need to replace the carbarator on. can i only put a sxr carb on it or are there others that can be put onto it?
Unless I miss my guess any triple cylinder carb will work as they are the same size (33mm) but you will need to have your jetting put into the donor carb unless you get one from the same cc sled.
