MM800
Your preference whithin reason! I can not figure out a stumble I have at 5200-5500 rpm. I have a 00 MM that I dont ride. It has bender pipes, carbon fiber reeds, peak head, boost bootle and transfer port inhancement ( I can get into that if you think it is an issue). Im running 140 mains, 52.5 pilots, air screws at 2 and 2 on the needle with 2 washers. If Im reading it right this is benders set up for 3500-7000. At 2500' it fires nice, idles high (2500). When you punsh it, it revs quick and smooth to 5200 stumbles to 5500 and goes. It has been like this for years. What the hell? Ok to the person who gives me the fix, I will send the m the money for there favorite booze. Up to 100.00 Im so tired of trying to figure this thing out. So the challenge is on. Give me your idea and I will try it and let everyone know. You should pm me so if some one has the same idea Ill look at the time. Good luck.!
