Crank Or Clutch Is Bent
I bet it is just a optical illusion!! Seen it all the time!!! Run her buddy!!
Skydog
SRX700guy said:
yes it is ok just don't rev it up
I agree, don’t rev it too much, what worst though is to rev a sled with the clutch on and no belt, the sheaves will slap together real hard.
How many miles are on the sled total? You mentioned that you just bought the sled about 1,200 miles ago so I assume there was a previous owner, do you have any idea how he maintained the clutches?
The issue may be caused by a worn bushing on you movable sheeve. They are a lubricant impregnated nylon fiber-wound bushing that does need replacing from time to time. If the previous owner did not maintain the clutches properly this bushing may be toast and causing your issues. The other thing I can think of is motor mounts. Are they tight, missing any bolts, broken?
Mills
It has a little over 6,000 miles. I am the third owner so I do not know the past on the sled. I tried to shake the motor and it did not want to move. The motor mounts looked strong but I will double check those as well. I guess I am going to invest in a puller and take the clutch apart to see what is going on in there. It engaes at 3,800 RPM and pulls upto 8,400 RPM.
Mills
It is interesting you mentioned this. The bushing could be worn as I only see wear on the shaft half way around. The whole shaft should see equal wear all the way around from the bushing, correct?
it the bushing for sure had it happen rode it wobblin like that had it explode let me tell you a clutch explodin is a serious event big chunks grenaded thru my hood an belly pan at 9100 i tucked an rolled an ripped my jacket off too chjeck for damage i damn near shat myself its cheap rebuild an ride on safely clutches are no joke i dont play around i hear any odd noise an i take her off an inspect lol jus my expiereince homie dont play dat
See post #4.
If I am only seeing wear on one half of the shaft, could it be a worn bushing and/or is the shaft slightly bent?
