SXR 700 problem
1993Vmax4
BC Canada
so i got a moist middle plug, there is also a very slight bog in midrange, i need to flutter the throttle a little at around 3/4 throttle to'clear its throat' so to speak, and then at WOT its still 300-400rpm down at topout rpm. lts also using more fuel (it think, not a huge amount- could be the changed riding style to compensate on the way home though)
lve changed plugs, coils, caps, pulled and cleaned carbs (i thought i may had droped a main jet,no such luck). l recently rebuilt the carbs so it isnt loading with fuel cos of shot orings seals etc. floats-level good, no fuel from vent tubes.
Checked comp good-within 3psi accross the board.
l gave the reeds a quick look with a mirror for any obvious failure..................................and i think that maybe my problem, could a chipped corner of a reed that i cannot see without taking it apart cause these kind of problems?
Can reeds just become weak (1997 sled 5000km).................................what have i missed :o| :o| :o|
Did you get the main jets back in the right place I know they stagered jets.
Hey Joe,
Thanks for the imput.
Forgot to say problem has just started on last ride, has been fine for 300kms
tested coils plug caps with voltmeter on top of swaping.
not loosing coolant.
97srxXT said:
Had a similar problem and did all the same stuff and It ended up being the stator going.
Hello 97,
...................................yeah, there is always that @$#*#%!
ls that what they call the 'charge coil' in the manual? l will test that with a voltmeter
