anyone got the manual for it ..the speedometer stop working on the sled
AndyC
Sensor is located under the secondary clutch. Check it there or the connector it located under the left side vents by where your knee is.
make sure the bolt and gear is still attached to the end of the driveshaft.
then check to be sure the sensor is still attached and the wires arent bad.
if these two items check out to be good, you can test for voltage at the sensor. you will need a 12v power source and a multimeter.
