srx 700 tripple spark plug issues
kedarganesh30
massachusett
Hi Guys,
I have a problem with my 99 srx 700 tripple tripple. It just start killing the plugs, i replace with new ones twice and it just kill them. I replaced the 3 coils but still does it. First the center cylinder goes then the one to the right goes but the one to the left stayes good. i checked the oil adjuster and its fine.
Any help will be appreciated.
kedarganesh30 said:
Hi Guys,
can you expand on killing plugs? What exactly is happening to you plugs, what do they look like etc.
Check the choke to see if it is sticking... Did anything get moved in the engine compartment, i.e. had to push cable to get to another issue? you may have unseated the choke cable and they are sticking on now.
the sled wont start until i repplace the plugs the center and left plugs are wet but the right one is dry if u r looking at the sled. the sled also miss fire and does spit and spat if thats the right terminolgy.
How many miles are on the sled? Sounds like the floats either need to be adjusted or the needle and seats need replaced.
