Amsoil Interceptor, and nothing else. Klotz or Shell Advance Synthetic would be my 2nd and 3rd choice if I didn't have access to AMS.
Bluemonster2
Shell advance ultra here. Jaso fd now, doesn't get much better than that.
meat12
At first I thought it was just a joke to get things going again, but it was an actual question. Funny!
Klotz and nothing else. I run it in everything.
Bluemonster2 said:Shell advance ultra here. Jaso fd now, doesn't get much better than that.![]()
same
Hash oil and nothin' else.
mxmantater746
Maxima Premium 2
Bluemonster2
This is a rundown of the different ratings givin to different 2 stroke oils going from worst to best. JASO FD is the best you can get right now and shell ultra is cheaper than most JASO FC oils from other brands.
Specifications for Two Stroke Oil
NMMA TC-W3 – two cycle water-cooled, third generation. TC-W3 obsoletes TC-W & TC-WII. Oils with this spec do not use metal based additives, and are ashless. This is an outboard specific spec.
API TC – only API spec established for two cycle engines. It regulates lubricity, detergency, ash content & pre-ignition. Oils with this spec are typically using metal based, ash producing additives.
JASO FA – original spec established regulating lubricity, detergency, initial torque, exhaust smoke and exhaust system blocking.
JASO FB – increased lubricity, detergency, exhaust smoke and exhaust system blocking requirements over FA.
JASO FC – lubricity and initial torque requirements same as FB, however far higher detergency, exhaust smoke and exhaust system blocking requirements over FB.
JASO FD - same as FC with far higher detergency requirement.
ISO-L-EGB – same tests and requirements as JASO FB.
ISO-L-EGC – same tests and slightly higher detergency requirements (piston varnish) as JASO FC.
ISO-L-EGD – same tests and requirements as JASO FD.
• National Marine Manufacturers Association (NMMA) is based in the USA.
• American Petroleum Institute (API) is based in the USA.
• Japanese Automobile Standards Organization (JASO) is based in Japan.
• International Standards Organization (ISO) is based in Europe.
These specs are established by different governing bodies located in various parts of the world. They all serve the same purpose; to give consumers a quantifiable way to measure the quality of 2 stroke oil.
What does all this mean for your yamaha snowmobile,
Most OEM 2 stroke oils fall in either the JASO FB/ISO-L-EGB (Good) or JASO FC/ISO-L-EGC/API TC (Better) category, although the container and the owners manual will never actually list an oil spec. OEM’s prefer just to recommend their private label product and tell you there is no known equivalent. It is easy not to have a “known” equivalent if you do not look for one.
The toughest spec currently obtainable for two stroke oil is JASO FD/ISO-L-EGD. Any oil listing an JASO FD/ISO-L-EGD rating is preferred for a snowmobile, dirt bike or PWC. Common sense should tell you, using an oil (including OEM oil) that does not list a rating usually means it does not obtain these ratings, otherwise why would they not want to list on their product.
Bluemonster2
Just another quick point, I noticed that amsoil has a JASO fc/api tc rating on there interceptor and dominator and at 14 bucks+ a litre your better off using somthing else.
rx1jim
I used to used Golden Spectro, about 10 years ago I switched to Amsoil. I have gotten good results with Amsoil.
s10mike
thanks guys, i'm def going with srx700, and using hash oil. now if i could only remember where i put it.
A couple of bucks
s10mike said:hash oil.
With me needin lots of pain pills........I'd like some of this.
Move to WA.. make sure you trade in for a mountain sled too.A couple of bucks said:With me needin lots of pain pills........I'd like some of this.
