I have like 5 new belts here.Now tonight I noticed the 2 end numbers are different..WTF!! I have 3 belts new from years back that are 8DN-17641-00 and I have 2 new belts I got last fall that are 8DN-17641-01.The -01 belts are at least 1/4" longer..why is that. No wander today my belt seems lower in secondary and the belt isn't climbing high enough in the primary according to my black marker lines I placed on the sheaves.Normally with the -00 belts new,I don't have to put any shims washers behind the secondary.Now it looks like with the -01 I will have to.Why was the spec changed?I also marked the helix ramps with black marker and the buttons aren't going all the way down either..thus I don't have full shift out at wot..this is a little crazy if you ask me.So I will have to shim for the -01 belts alot more then the other...
