a few years back I changed the jackshaft because of a spun bearing/set-screws...The retainer plates for the bearing couple the bearing and get bolted in place on frame,all on the inside.Well today I notice my secondary backside of sheave that moves is grinding against the retainer plate,yet on the other sleds it didn't.Then I noticed I installed the retainer plate on the outside of the frame,and the other plate on the inside as should be..Well this is the cause of the grinding going on.The plate protrudes way to much towards secondary..like 5mm at least to much.So every time I pin it and the secondary wants to open..it stops there and starts grinding,then the belt is not dropping all the way and then the primary is not pulling belt up all the way..or it is trying to and maybe stretching the belt.WOW! how did I manage to do this.....Probably losing 10 to 15 mph by clutches not shifting out all the way....All I can do now without spending tons of time removing chaincase,gears,rotor,bearings just to slide shaft back..is to remove air box,undo the 2 bolts..take plate to grinder and grind her down thinner and re-install and see how sled performs.It never fails with sleds..you have to have your eyes and brain coordinated and not let stupid things happen.It would be something if the SRX starts to run better now...imagine a whole 5mm sticking out more then normal..that has to change things...
