super1c
Super Moderator
Have been wanting to get a project viper for the daughter and i to work on over the summer. Well i found one and its a diamond in the rough. Mechanically it is sound. Has 3200 mi from one owner, comp spot on, drive in great shape, track decent which was way more than i could hope for, and suspension looks good. Will get the BTV treatment this summer. It does have a slight thud at slow speeds under power but im sure its the belt as it was original and the track was a tight as a rubber band. Same problem i had with my viper and turned out to be belt. At worse a bad bearing or chain case. I have all those parts extra so no cost either way. Cosmetic is not bad. Hood looks good, does need trim. Seat perfect. Needs handlebar pad (got one
) Big deal will be taking front end apart and all new powdercoat to trailing arms and radius rods. Painted them blue for what ever reason, maybe bent them at one time ? Who knows. My daughter says she wants pink accessories, tunnel trim, radius rod covers, shock covers ect. We will see on that, depends on how much work she puts in also. Will completly go through engine also. Might start a working log on it. For now will get engine fogged and put a way till it gets warm.
