just got a 2004 viper s going, couldnt get to ride it earlier. been riding on hardpack trails and ice.its got a 1 1/4 track. are you supposed to feel a vibration all the time or do i have other issues? have a srx and theres no vibration at all on that on the same trails. what do you guys think? thanks alot, you guys are awful helpfull!srx is a lot more solid than viper
journeyman
bobsiding said:just got a 2004 viper s going, couldnt get to ride it earlier. been riding on hardpack trails and ice.its got a 1 1/4 track. are you supposed to feel a vibration all the time or do i have other issues? have a srx and theres no vibration at all on that on the same trails. what do you guys think? thanks alot, you guys are awful helpfull!srx is a lot more solid than viper
Is there any ice or snow buildup underneath? Mine does this when I have buildup. Also were the front heat exchanger protectors left in place? I believe the track (1.25" or larger) will rub on those if not removed. Of course the worst case scenerio is a bad bearing, something out of alignment, chain case issues...etc.
04 vipers came with the ripsaw. might have a bad bearing in the skid or behind the secondary clutch.
If it is studded, you could be feeling the studs running on the ice/solid frozed ground if you have little snow for the track to set on, as they will/should protrude over the lug.
i found it.1 the jackshaft is bent. you guys ever see that?
