tsquared
my buddy burnt his center cylinder down, pluged a jet. We put a new piston and rings in,with plans on a full rebuild in the summer. Now that cylinder will not pull fuel. We have cleaned the carbs but still no fuel.
I did not hone the cylinder as there were no scratches but could the rings not be seating causing insufficent vacum to pull fuel? if we dump fuel down the cylinder it fires up. If I plug the carb with my hand it will run, choking seemsto make that cylinder fire, but the other two bog. there is noticable less vaccum on that cylinder. Is there somethingin the bottom end that I need to worry about
I am just trying to confirm that skipping the honing step could be my problem. I know it has been jetted down so I am going to go back to stock size on that cylinder for the remainder of the break in.
Getting to this point we have checked
-sled is 97 sx 700
-new plugs
-changed coils
-changeplug ends
-cleaned carbs
-checked reeds
-checked compression 140 cold across the board, 135 hot.
Thank you for any input
-sled is 97 sx 700
-new plugs
-changed coils
-changeplug ends
-cleaned carbs
-checked reeds
