Super Sled said:With Yammi's, we call it twist, or wind.
Set one spring end in one whole on the helix and then in a hole on the secondary sheave.
The add the number and multiply by 10 for your degree of twist, or wind.
Most go 3-3 for a 60 degree wind to start, that's where they come stock.
9801srx said:The tech section says 120 degrees.
So you put the spring in the hole in the sheave.
On the helix you can use any one of the three evenly spaced holes to get the 120 twist.
The other hole that is next to one of the 120 holes is the only fine adjustment on that clutch,
and lookes like it would give you about 130 degree twist.
9801srx said:The tech section says 120 degrees,
so you put the spring in the hole in the sheave.
On the helix you can use any one of the three evenly spaced holes to get the 120 twist,
the other hole that is next to one of the 120 holes is the only fine adjustment on that clutch and lookes like it would give you about 130 degree twist.
