yamaddiction
i know this has probably already been asked but i went for a ride a couple weeks ago and did around 100 miles and a tank of gas, but i also used around 3/4 of a tank of oil does this sound normal??
n2oiroc
sounds like a lot of oil to me!
excel V
- Apr 8, 2004
How much gas and how much oil did you use? It should be 50:1 ratio.
yamaddiction
well i'm not exactly sure what the srx holds for fuel but i started with a full tank refilled it when i got down to the 1/2 tank mark and buy the time i was done riding it was back at half, so i'm assuming around a full tank of gas which i think is somewhere around 11-12 gallons???.. i also started with a full tank of oil and when i got home i checked it and it was damn near empty...
My SRX gets about 200 miles to a quart. Sounds like something is screwy with your sled.
98srx6
Make sure your oil cable is adjusted to spec. I believe it should be set at ~25mm of free cable.
SRX7
23mm free play.Something is not right.
unimog
Something is wrong, I can usually go 3 tanks of fuel before worrying. It also seems that when the light comes on you will definitly have enough oil to run a full tank of fuel. Just by chance was it parked over the summer next to an Arctic Can't, maybee it caught an STD, snowmobile transmitted disease.
yamaddiction
where should i be looking for the free playSRX7 said:23mm free play.Something is not right.
or would that be forplay
SlowSRX
- Mar 11, 2004
jwifferdill said:My SRX gets about 200 miles to a quart. Sounds like something is screwy with your sled.
I get about the same. Last year it was 100 miles to the quart. The cable was off. I switched to spectro synsnow too 50 to 1.
yamaholic22
check the cable gap, it is in the tech pages. If you use a good synthetic oil you can go 1 or 2mm more for a little leaner oil pump setting.
