thnx thnx bob and rustman ...........nice summer project
mod..bring your sled down here..we have another 4 to 6 inches of new snow coming tomorrow..yahoooo!
hey bob the 98 srx and 95vmax4 and up do they have the same diameter secondary
YAMMIEGOD3:16
BIG PROBLEM WITH THE 92-93-94 SECONDARY WAS NO HELIX SELECTION.. 3:16 (yammie tony)
YAMMIEGOD3:16 said:THE CHAINCASES ARE NOT SAME ON THE 750 AND 800 VMAX 4 ACCORDING TO YAMAHA. I POSTED THEY WERE AND I WAS WRONG. THE COVER IS THE SAME 92-96, BUT THE 95/96/97 INNER CASE TAKES LARGER BEARING. WITH THAT SAID, THEY LOOK ALIKE AND WILL BOLT ON EACH SLED, BUT ONE WOULD NEED A JOBBER BEARING TO GET IT TO WORK. EVERYTHING ELSE WILL INTERCHANGE. RUSTMAN DID SOME GREAT RESERCH ON THIS. 3:16 (yammie tony)
awsome yammi still need a good clutch set up lolll
YAMMIEGOD3:16
I HAVE AFEW VMAX 4 CLUTCH SET-UPS. 3:16 (yammie tony)
YAMMIEGOD3:16 said:I HAVE AFEW VMAX 4 CLUTCH SET-UPS. 3:16 (yammie tony)
throw me one ..i think will go with the 8bu-10 and see from there with the helix
YAMMIEGOD3:16
GIVE ME ALITTLE MORE INFO ON THIS SLED. IT WAS CONVERTED TO A 800, BUT STILL HAS 750 SECONDARY ? WHAT PIPES. WHATS IT NOW FOR CLUTCHING. 3:16 (yammie tony)
YAMMIEGOD3:16 said:GIVE ME ALITTLE MORE INFO ON THIS SLED. IT WAS CONVERTED TO A 800, BUT STILL HAS 750 SECONDARY ? WHAT PIPES. WHATS IT NOW FOR CLUTCHING. 3:16 (yammie tony)
secondary will be replace with newer style ...pipe and everthing else should be from the 800 cc ...still not sure for gearing didnt open up the chaincase yet ....for now it got 89a weigh in it with stock convertor with a 39 degree helix ...i'm sure that sled doesnt rock at all
modsrx said:hey bob the 98 srx and 95vmax4 and up do they have the same diameter secondary
The secondaries are the same diameter.
Bob
YAMMIEGOD3:16
IT LOOKS TO ME YOU HAVE THE 800 ENGINE SWAP BUT SOMEBODY LEFT THE 750 CLUTCHING. 89A ARE 750 CLUTCH WEIGHTS OR CAME ON THE 750 VMAX4. THEY DO WORK GOOD. NOTHING HERE WE CAN DO UNTIL YOU CHANGE SECONDARY. 3;16 (yammie tony)
YAMMIEGOD3:16 said:IT LOOKS TO ME YOU HAVE THE 800 ENGINE SWAP BUT SOMEBODY LEFT THE 750 CLUTCHING. 89A ARE 750 CLUTCH WEIGHTS OR CAME ON THE 750 VMAX4. THEY DO WORK GOOD. NOTHING HERE WE CAN DO UNTIL YOU CHANGE SECONDARY. 3;16 (yammie tony)
yes he did let tht shitty clutch in it lollll...summer project let me know where to start with the clutching with the new secondary
just checking on my 2000 SRX secondary it won't go on my 97 V-max but will the helix's work I have 5 that go on my SRX secondary
needaSRX said:just checking on my 2000 SRX secondary it won't go on my 97 V-max but will the helix's work I have 5 that go on my SRX secondary
Yes your SRX Helixs will work on the 1995 and up VMAX4 secondaries.
Bob
