Have Primary Apart - What To Check For?
Is changing these bushings something an average dude could do or is it a high tech and expensive tools job? Mine are gone (wore out) on both primary and secondary.
Those bushings are pressed fit and requires a special tool to do so. Also the clutch spider requires a special tool as well the seperate the 2 primary sheaves.
Search for "grunt tool" here and you'll find some home made tools used to disassemble the clutch.
yamabrute said:
I seen the grunt tool, looks like something I could make. Was wondering more about the bushings. Thanks.
I use an arbor press but have banged them in on my Polaris' before I got the press using race installers.
sgauthier said:
i would since you have it apart. i noticed that royal distributing sells the service kit for those primaries which include those 6 sliders. not sure how the quality compares to the OEM parts. a lot cheaper thou, might be worth a try if they have any in stock. ;)!
I bought that kit and the one bushing for the cover is made out of plastic and the other for the moveable sheave is some cheap metal with teflon that I can scratch off with my fingernail. The pins for the rollers are also the wrong diameter and length. Going to return it and go OEM. Thanks for the advise anyhow.
don't buy any bushings,ramps or buttons from Royal,,there are pure sh*t.Don't know why they would even want to sell such crap.I have a thread showing how to make a tool to remove the sheaves in primary...
