Fro
For asphalt runs.
yeppers, if not it will close when it hits right temp.
YAMMIEGOD3:16
YES YOU DO . 3:16 (yammie tony)
Fro
Thanks.
For those that run them on an SRX, where do you put your quick disconnects? On the line from the bottle to the heads?
Any pics on how you did it?
YAMMIEGOD3:16
YES AGAIN. 3:16 (yammie tony)
I used the back and eliminated the rear heat exchanger from the mix.
pump through the head, ruturn out the overflow. sounds tedious, but easily overlooked. when you turn the pump off this direction will leave overflow full, other way will not.
Fro
^^^Thanks, that makes sense.
Building my cool down rig in about 2 weeks.
