Max Lug Height..??
That depends... if you stud it you'll want to keep the protectors in place, then a 1" Hacksaw or Predator would be a good fit. But without the protectors (if you don't stud) you can probably fit a 1-3/4" it would be tight, you can go bigger if you change the driver from a 9 tooth to an 8 tooth. The 8 tooth will give you more room up front. Some guys use a 8 tooth with a 1-1/4" and stud it, then you can keep the protectors in. Using an 8 tooth you'll probably want to change the gearing.
