track spin,need help!!
REDMATER
tya
ny
Website
mysite.verizon.net
here the deal
98 sx700
punched silencer\reed notch
g-p-g primary spring 8ab weights w/2.4 rivets in both holes
49/43 helix green seconday spring at 70*
8.8 lug track 120 studs
since i have done this work to my sled it doesnt hook up as as well,track spins more than prior to the clutch mod.i know i have gain a few more hp with notch/silencer mod
is there a better rear suspension set up i can go with,i have the pioneer performance long travel rear shock up grade,i also have maxxperf quick rods set at 4.5 lines
no the stock track when to SH*T pile with1200 miles on it,i got a camoplast 8.8 lug on it now,3season on it and is is excellent shape..s
try moveing the rear holes on the transfer rod to a 99 up set up that is ahead of the holes now it will take shorter rods or modify yours for fit adjust for inch and a half travel bye cutting down loc nuts or removeing spacers than set for soft ride or med than hang on.
