here the deal
98 sx700
punched silencer\reed notch
g-p-g primary spring 8ab weights w/2.4 rivets in both holes
49/43 helix green seconday spring at 70*
8.8 lug track 120 studs
since i have done this work to my sled it doesnt hook up as as well,track spins more than prior to the clutch mod.i know i have gain a few more hp with notch/silencer mod
is there a better rear suspension set up i can go with,i have the pioneer performance long travel rear shock up grade,i also have maxxperf quick rods set at 4.5 lines
98 sx700
get a better track....or try more studding.....
seanmurphy26
ya thats what i was going to say, studing made a big differnce on mine.
yea i figured sled you would give me that advice...hahaha i love the clutch set up great corner to corner very snappy
really tho, if you have the stock track it wont last long....that stock track is a heep of crap....
no the stock track when to SH*T pile with1200 miles on it,i got a camoplast 8.8 lug on it now,3season on it and is is excellent shape..s
im think of going up to 144 or 168 studs
I had great success with 168... http://www.totallyamaha.com/snowmobiles/aaTECH/Stud Patterns/Stud Patterns.htm
thanks sled
Mr. Sled, what track would you recommend and would that fit or are other mods needed?
If you dont want to change the drivers for a ripsaw then I would go with a 9830.
blue who
try moveing the rear holes on the transfer rod to a 99 up set up that is ahead of the holes now it will take shorter rods or modify yours for fit adjust for inch and a half travel bye cutting down loc nuts or removeing spacers than set for soft ride or med than hang on.
