The tech book tells that the sled is jetted for -7c (20f) at 300-1700ft (100-500m). It has MJ#1 #145; MJ #2 #3 143,8
PJ #45
JN-3
PS 1-1/2
at -18c or 0f it should be
mj #1 #146.3, Mj#2 and 3 #145
Pj #45
JN-3
PS 1-1/2
what does this mean?
Jetting is not required before temps plunge below 0f? )-18C does this mean that at +1F, or -17c you can run the sled at WOT without burning down?
Will the sled burn down at lets say -13f at 0-100m (0-300ft).
I've always heard that those triples are unsensitive to temp changes, but is this to challenge your luck?
I've heard that you can run on the pilots when the main jets are lean. From what rpm to which rpm do you run on the pilots, when do the mains take over?
PJ #45
JN-3
PS 1-1/2
Pj #45
JN-3
PS 1-1/2
Stock jetting is good to as cold as I have ever seen!! Most guys run 142.5 mains & still good at -20. The pilots actually contribute about 5% of mid-range & hi speed fuel supply.
Does this mean that one could run at WOT at -13f and not burn down?
The sled was snappy like %(#&¤(/& at this temp, I thought it was due to a lean condition..
Have you taken into consideration our low altitude? 0-300 ft?
I see that the 142,5 jetting is good for -02f at 3300-5500 ft..
thanks
thanks
bolin22
pilots are used from idle to under half throttle....then the mains kick in .....why do you want to change your jetting?
MM700
- Nov 3, 2003
After messing around jetting my 2000 MM700 3 times when I went to the mountains and back, I had enough. I installed Holtzmans Vari-Flow and temp gauges because I didn't believe it would work. I ride at 1600 in North Dakota, 6000 feet in South Dakota and 8000+ in the mountains and this thing is spot on. I installed the new style on my wifes MM and one on my son-inlaws 2004 Mountain Viper, spot on. Just like the Ronco Grilling machine (just install it and forget the jetting)
