I have a general spec book for the vmax/venture line and it shows no gaps. I know any of the model specific books I have, viper, and srx have spacific gaps listed. If you can find the specific manual at the dealer, you might find them. I have found with two up sleds, the standard gap works, 14-16mm but I will set the sleds up for spring tension on the low setting on the fra, then when you want to ride double, you can just switch to the high setting, your gaps will still bottom out when riding double but you will have the better of both worlds. If your going to ride double all the time, I would set the sled up with two people setting on it full weight, with fra in the high setting. This will give you the best valving and best gap settings for ride and handling but not when your riding alone, even if you bring the fra back to low.
I wouldn't get too worried about having an exact gap. Unless your skid has been rebuilt and tightened up, all the extra slack in all those bushing start adding to the gap.
