Aircraftman
Does anybody have intelligence on how a Hauck 2001 SRX Race CDI will respond to being run without the TPS hooked up. Going to run it on the dyno but i wanted to make sure i wasnt battling any gremlins by doing this. Does it need a resistor hooked up? should i install it on the throttle?
Thank you
Thank you
valin
There will be no issues. Be sure to connect the wires together in your harness.
Aircraftman
Connect all the TPS wires together? Can you specify?
Thank you
Thank you
valin
Nevermind that.....pay no attention to me. I was thinking of the tors. My excuse is that it's the summer.
You won't have an issue with the TPS.
Aircraftman
LOL! thanks. for my own info, what does the TPS normally modulate, timing curve or power valve or both and how?
Aircraftman said:LOL! thanks. for my own info, what does the TPS normally modulate, timing curve or power valve or both and how?
While the thread below doesn't answer your question specifically, it does have info on issues related to the TPS or more correctly, what an in range failure of TPS output might cause.
http://www.totallyamaha.net/forums/showthread.php?t=77080&highlight=tps
toydoc
Aircraftman said:Does anybody have intelligence on how a Hauck 2001 SRX Race CDI will respond to being run without the TPS hooked up. Going to run it on the dyno but i wanted to make sure i wasnt battling any gremlins by doing this. Does it need a resistor hooked up? should i install it on the throttle?
Thank you
Can you plug the TPS in?
Aircraftman
Thank you for all the info. Even though the TPS will not affect full throttle timing, it appears that it does affect timing everywhere else so it only makes sense to run a 4 cable throttle and mount the TPS on a bracket and hook it up in order to take advantage of the midrange power the timing advance provides. How do you think I should mount it to keep the same rotation aspect?
valin
Personally, I wouldn't worry about it in a race application. You are either right before engagement, or at WOT. The timing differences will not affect you. If it's a bit lazy down low, increase your engagement slightly. I have been running Mach Z carbs on my SRX's for years, and nothing is noticeable with or without the TPS.
yamalars
X2 on that! I to was worried about running 38's w/o tps.valin said:Personally, I wouldn't worry about it in a race application. You are either right before engagement, or at WOT. The timing differences will not affect you. If it's a bit lazy down low, increase your engagement slightly. I have been running Mach Z carbs on my SRX's for years, and nothing is noticeable with or without the TPS.
But its even snapier now compered to the 33's all the way from engagem.
and up. Runs real good even on the trails =)
toydoc
Aircraftman said:Thank you for all the info. Even though the TPS will not affect full throttle timing, it appears that it does affect timing everywhere else so it only makes sense to run a 4 cable throttle and mount the TPS on a bracket and hook it up in order to take advantage of the midrange power the timing advance provides. How do you think I should mount it to keep the same rotation aspect?
Take a oil injection pump with cable and use it as template to mount the TPS to the injection lever arm. After you get a base line on the dyno, I'd make a run with TPS locked WOT and also move it around and see what it does.
jabber800
I have 38's on my 600 pro stocker, we run no TPS. As Ryan was saying I dont think its worth the effort! We engage our 600 near 7000rpm's , motor runs ar 9800 The timing between those two points is the only thing to worry about and trust me its not at 7000 for very long!!
Aircraftman
Thank you all very much for the info. I decided to run the TPS. I figured if yama took the time to put it there, and drive a 3D timing map with it, it must be worth something in the midrange, albeit for not very long in a drag application. Since the game is all about the first 60' then might as well try it. I ordered the A2 pot and "modified" (LMFAO) one of the old 33 carbs to drive it with a 4 cable throttle. I will get some part throttle dyno info to post as well as some 60' times with and without it in the future.
again thanks!
again thanks!
staggs65
did you ever dyno this and compare results with and without the tps?
