I am fairly sure the engine is a 90 or 91. We have 38mm carbs off of a Mercury Trail Twister, that are bored to 39.5mm.(Non liquid cooled carbs) We are currently at 340s for mains.
Everything from PSI that I have dug up has said that they ran 360 and 370s for mains, but they were also running 44mm Mikunis.
I would just really like to have the PSI, AAEN, RPC, or Bender porting specs for a baseline. If anyone has these I would greatly appreciate it if you could post them on here.
I have already done some porting but I left it fairly conservative on the exhaust ports, which I have found now that I am not reving enough to get to peak Hp.
Again guys, I have a freak show application, engine is in a 1980 SRX440 chassis, YPZ clutch, PSI twin pipes for 570 exciter, shaved cylinders and head, and many other mods. I really just need the specs from the above mentioned companies to get an idea of their baseline for their race only engines as this sled is only intended for radars and drags. I can take care of the rest with the guys I am tuning this thing with and we'll do our own version of the porting based on the specs I am requesting.
Thanks for any and all help. I appreciate it.
BA
