panthers06232
i have a 98 srx i am putting rings on it right now the jug fell off the seat and a piece of the bottom broke off how they have metal tha sticksout of te bottom one large chunck and two smaller one of the smaller pieces broke off if it putit back together this way will it run or do i have to buy a new jug
Going to have to either have it fixed or get a different one.
panthers06232
what does those metal pieces actually do and how would i have it fixed
YAMMIEGOD3:16
DON,T GET ANY IDEA,S HERE. THEIR A DIME A DOZEN. GET ANOTHER JUG. 3:16 (yammie tony)
panthers06232
do you know of anywhere i can get a jug
Find a good used one here, or Eckhoff's in New London, MN has exchange ones, or one of the other cylinder plating places could either fix it or possibly exchange it.
panthers06232
will it run if i put this one back on it
If out is part of the mating surface, then no. you ned a new one. post a pic of it.
panthers06232
i am at work right now i will when i get home i thought they were just for alignment reasons
panthers06232 said:will it run if i put this one back on it
Probably - but it's hard to say for how long. Might go forever - might go for a few minutes. Fix it right. Good used jugs can be found all over the place for $100 - $200. Re-manufactured/exchange/repair will run $225 - $300 depending on the route you take.
panthers06232
it isnt missing out of the actuall cylinder just the little extension that comes out of the bottom there are three of them on is just chipped in half
crazykid
Replace It!!!!!!!!!!!!!!!!!!!!
its likely the rear skirt of the cylinder, if you run it without it, youll have engine failure from the piston rocking around and not supported at BDC, I would definitely not do it!
YAMMIEGOD3:16
LOL 3:16 (yammie tony)snopax said:I'd run it.
Are you serious? Do you know whats going on here??
Lol, no not serious
panther u should take some advice from the guys here and take this to someone who has some experience with sleds it will save u alot of money in the long run. as ruining a weekend out with ur buds with a breakdown being towed back and if not ruining ur cases u deffinately need some hands on guidence but anyhow good luck
Good advice here, especially from mrviper700. That is what those "extensions" are for - to keep the pistons aligned in the bore at the bottom of the stroke. You can replace just the jug now, or you can run it as is with a very good chance that you will destroy the whole engine (cases, crank, pistons, and jugs) $100 or less now, or $1000 later.
viperking
I have a used one for $150 plus shipping, let me know if you want it thanks
