motor boggs
primary getting that hot your sliping the belt some ANDY. THAT 80 TWIST SHOULD CURE IT. GET SOMEBODY WITH A TREMEL AND A STEADY HAND AND CUT MORE ENGAGEMENT IN THOSE H/C. 5500 IS THE TICKET FOR RACING. 3:16 (yammie tony)
Tony do you have picture to go by on notched HC's and also, can you run HC's without any heel weight, EX no set screw just empty, was thinkin of tryin but didn't
THATS EXACTLY WHERE YOU WANT TO WORK NOTCH. AND NO ANDY I DON,T HAVE PICTURE. NO WAY WILL YOU BE ABLE TO RUN H/C WITH HEEL EMPTIE. ESPECIALLY ON A SRX. 3:16 (yammie tony)
