Well, here goes, looking for some good insight on what I have going on here. This is a 98 SRX engine with about 3500 miles on it, the last 500 of them in the mountains w/ a mod sled. The jetting is at 150 straight across Needles at 3rd clip, no washers, stock SRX pipes, w/ Bender can. Stock airbox and ATACC for altitude compensation, my base Jetting is for 1000' altitude and about 0 degrees F. I am looking at the wash I have now, and I want to say that it is right on the line where I might be tending to the lean edge, but not too bad. Here is where things get interesting, I am adding some Hauck handbuilt pipes, and Mega Power Heads. I am trying figure out how much I may have to change the jetting for this combination. My guess would be that I would go up two sizes to a 152.5 across since I feel I am slightly lean anyway, I have ceiling some room to work with, and I would maybe put a washer inder the needles at the third clip. What do you guys think of what I have here. The pistons are arranged from left to right - PTO, Center, Mag with the exhaust side of the pistons facing the right.
BTW - You may notice the mag side has some material melted off the crown of the piston on the exhaust side of the piston. Comments would be appreciated on this condition. My guess is this: being the wash is pretty decent, and the fact that I had a bad spring on that pipe which was replaced halfway through the season last year, the melted edge is caused by having a loose pipe on that cylinder.
Well guys, have at 'er, please keep comments constructive...
Thanks!
Thanks!
