tgillespie
Hey, I have an 01 SRX, stock motor, I just did a compression test, My question is what is a good psi across the board??
Compression gauges vary a lot, the important thing is that the figure you get for each cylinder is close to one another and not super low. I would say anywhere around 125 - 130 lbs psi in all three cylinders would be just about right.
tgillespie
I got just a bit over 120 close to 122 on all 3 cylinders. Is that low or ok?
That's definitely good on a stock motor! No worries.
super1c
Super Moderator
tgillespie said:Hey, I have an 01 SRX, stock motor, I just did a compression test, My question is what is a good psi across the board??
Whats your numbers? Laporte is right on with being equall in all three, meaning within a couple percent of each other. The Number will depend on gauge, warm or cold, wet or dry, how hard you pull, ect......
tgillespie
Good deal, thanks for the info.
super1c said:Whats your numbers? Laporte is right on with being equall in all three, meaning within a couple percent of each other. The Number will depend on gauge, warm or cold, wet or dry, how hard you pull, ect......
Agreed, lots of variables to consider for sure.
super1c
Super Moderator
Woops i was a little slow! Oh well he beat me to it with the numbers LOL! That looks good to me. chris
