SRX Compression??
tgillespie
Minnesota
Hey, I have an 01 SRX, stock motor, I just did a compression test, My question is what is a good psi across the board??
Compression gauges vary a lot, the important thing is that the figure you get for each cylinder is close to one another and not super low. I would say anywhere around 125 - 130 lbs psi in all three cylinders would be just about right.
Whats your numbers? Laporte is right on with being equall in all three, meaning within a couple percent of each other. The Number will depend on gauge, warm or cold, wet or dry, how hard you pull, ect......
Agreed, lots of variables to consider for sure.
