I ordered the sway bar bushings and cover plates and rivets.Wanted to remove the plates the other day and now notice the damn plastic of the bellypan cross right over the bottom rivet and the whole corner of the cover plate.How the hell do I get that rivet out now??I am not going to remove all the plastic bellypan to to replace these.There is also some kind of seal there between the plastic and plates,probably so water doesn't get by.Do I have to maybe drill a large hole thru the plastic to expose that rivet and then try to wiggle plates off???Man why did they have to have the plastic go over them plates..bad design or what..Any solutions here guys or hints????Thank-you again..
