thetorches
Removeing W-arm on 2002 Viper
Do you need to remove skid to replace w-arm on '02 viper and if so, is it hard to do. Thanks for any info.
it can be done, but your knuckles, mind and cuss jar will be alot happier if you remove the entire skid. actually the cuss jar will be happier if you opt for the hard way.
its alot easier just to drop the skid. if you have an air or electric impact, its even easier. lots of good advise on the subject from the members here, just ask if help is needed.
I have done it both ways...actually real easy once skid is out and you can check everything else at the same time.Removing it while in the frame is a little tougher,especially removing and re-installing the front shock
