my 600 has stock clutching i would like it to have a harder pull off the bottom end i dont mind losing top speed i do alot of drift riding and i want alot more power off the take off my average riding speed is 20-50mph sometimes 80+ when i want to open the sled up like i originally stated i dont mind losing top speed i dont do much high speed riding i just love messing around in drifts carving and try to see how long i can hold the skis. i was think maybe a little bit stiffer primary spring or some heavier weights?
staggs65
gear it down some
wich gear top or bottom i dont no much about sleds i am mainly atvs so i dont know if the gearing works that same as a quadstaggs65 said:gear it down some
staggs65
less teeth top or more teeth bottom= less top speed/more bottom end
more teeth top or less teeth bottom= more top speed/less bottom end
can't really give you the best gear combo for your type of riding (I do the opposite riding) but others will chime in for sure.
