How do you know if a power valve is bad? I have one that is not connected to the cable. I do not know if the valve were the cable connencts too it is bad or not.
What is the proper way of attaching the valve back on the cable?
Can I just buy & replace one valve or do i need to replace all three?
sounds like the cable pulled thru valve top ...you could buy new ones at the tune of around 350 dollars ...OR you can send them to me and ill make them better than new with a stainless steel top for less than you can but one new one for ...and a new one will just pull thru again ..
What kind of turn-around time do you have on doing them with the stainless tips right now?
depends on how many i have to do ...my injury to my leg is getting better so i am able to do more again .....when i was uninjured all valves were done the day i got them and sent back next day ..i am shooting to do the same again ...except the days i have to go to thearpy ,,,,
