JeepJimmy
99 VMAX deluxe 700. would like to upgrade the headlight bulb. what are your opinions?
Use a XENON boosted bulb like a PIAA bulb or use a sylvania silverstar bulb, and STAY with stock wattage as larger wattage bulbs will cause issues if you have a heated shield or it may melt the wire harness.
A couple of bucks
I took out the Phillips X-treme power H4s. Not that they were bad, but as white as they are, we as snowmobiliers need a little bit of contrast w/ being on snow. Put in ..... http://www.automotivelightingusa.com/headlight-bulbs/halogen-bulbs/nokya-hyper-yellow-h4-bulbs.html. They are 55/60.
HID kit, simple to install, you allready have a battery in that model. best money you will spend, I have them in my cars and sled
A couple of bucks
That 'Rough Service' H4 bulb is right up a snowmobilers alley.s fortuna said:
