mods before winter
coryv4
Michigan
i am looking for some mods on my 98 600sx twin it is 100% stock i want to give it as much bottom/mid response as i can i am wondering what you guys recommend for mods as far as clutching and gearing goes i would like alot of low speed power i like to ride drifts and i would like some mods that would help get the skis off the ground.i dont want to tear into the motor if i dont have to i have a can maybe some heavier weights lower the gearing a little and maybe a taller track on my to do list before winter comes some quick help would be appreciated. what gearing/clutching would you guys reccomend i dont care if i loose top speed i hardly ever go over 70-80mph
thanks.
drop one tooth top get a pinkit from straightline perf to use cat weights and put a green secondary spring with a 51-43 rear helix prob arouns 51 grams should get you close
how much does this cost i really dont want to spend 200 bucks for a full clutch kit what is this pinkit?
Cheap fix is to go one tooth less on the top gear in your chain case will wake the sled right up, i did it to my 96 vmax600 mm that i use for ditch banging. Around $20-$30 on the evilbay
