A couple of bucks
Replacing the gaskets on my sons SX6 when the fresh reeds and the notched stop goes in. I found out that my O'Reillys stocks just about any size, thickness(measured in 32nds) and material. None of it is out front, you need to ask to see what they have in the back.
This particular stuff, which seems to be a direct match for the OEM intake gasket material, is rubber impregnated cellulose and is 3/32nds. Cost..........$7 and I could easily get 27 intake gaskets out of this sheet. Not that I'd ever need to. This stuff came in a roll but they had sheets of all different kinds of shtuff.
And a 1 hole punch is perfect size for these holes.
rx1jim
Nice, I use a similar material to make all sorst of gaskets for cars, tractors, and sleds. The material you have looks like excellent material. The hole punch is the perfect tool for making gaskets, been using it for over 30 years.
A couple of bucks
That stuff is no slouch either. It takes the exacto knife, w/ a fresh blade, a couple of passes in order to get through it.
A couple of bucks
ryan2001sx600r
i'd be worried if you ever needed to take them back off.
A couple of bucks
I have a sheet of gasket material that can make approx 27 more of them.ryan2001sx600r said:i'd be worried if you ever needed to take them back off.
A couple of bucks
rx1jim said:The material you have looks like excellent material.
It is leaps & bounds above the '12 pack' cardboard gaskets I used on my YZ when I was young & dumb.
ottawaair
Hey Now... I made quite a few Milwaulkees Best case gaskets back then.. Worked just fine.
ottawaair said:Hey Now... I made quite a few Milwaulkees Best case gaskets back then.. Worked just fine.
I can remember banging out a few T-stat housing gaskets with a ball-peen hammer and/or using oil on the gasket surface and imprinting it onto "gasket material".
A couple of bucks
Mine was High Life.
A couple of bucks
I also found the same exact stuff at Auto Zone out front.
Lol I just used keystone the other day on my tractor but u know im smooth like that
A couple of bucks
360miller said:Lol I just used keystone the other day on my tractor but u know im smooth like that
OK Keith
A couple of bucks
Keith Stone......that is.
shaggyzr2
I'm planning on making some new gaskets for my coolant rail on my srx, would I need to use the copper gakset spray or just use them without the spray?
A couple of bucks
It certainly won't hurt. I tend to overkill when it comes to possibly a fluid leaking.
I've used just straight silicone before without any paper gaskets,never leaked. Works in a pinch.I'm planning on making some new gaskets for my coolant rail on my srx, would I need to use the copper gakset spray or just use them without the spray?
