i run atf type f in my drag banshee would that work because i have a bunch of that?427cobra said:90W gear oil would be WAY to thick. Especially in sub zero temps. If you dont want to use the Yamaha chain case lube then the tranny fluid would be a good choice. Or some straight 30W with some Lucas oil stabilizer. (i ve used that combo in the past with good luck)
I have since switched to Polaris chain case lube. Yamaha's would work too....
