srxman06
Wondering what the best way is to clean the power valves on my 2002 viper? Have some carbon built up on them. Doing a top end rebuild so i want to clean those while its apart.
staggs65
soak em in simple green overnight. stuff does wonders on the carbon
scrape..scrape..scrape..there is no magic solution ..I have tried everything..nothin really works.You still have to scrape and scrub pad them to death...
tried soaking in simple green,brake fluid,break cleaner,gas,oil,paint thinners..nothin really does much to them..just scrub with green pads the best you can.
YAMAJOHNNY
Sea Foam seems to loosen the carbon up fairly well
staggs65
YAMAJOHNNY said:Sea Foam seems to loosen the carbon up fairly well
I heard that too but never tried it. surprised you had no luck with simple green blue. sure there's still some elbow grease involved but loosens up the bulk of it for me
daman has always told us he used airplane paint stripper and didn;t harm valves..hmmm!
rx1jim
Whatever you choose to soak them in, DO NOT soak them in an alkaline cleaner such as Spray 9, Castroll super clean, Purple clean or oven cleaner. These cleaners do a nice job of dissolving the aluminum.
The power valves are aluminum which has them been anodized to produce a hard aluminim oxide layer on it. The aluminum oxide layer prevents the valve from galling/sticking to the aluminum cylinder. The aluminum oxide also acts as a hard base for removing the carbon build up. The aluminum oxide is not pinhole free, so the strong alkaline cleaners get through the pinholes and dissolve the aluminum. I had a few badly damaged power valves which I used for cleaning experiments.
I clean my valves pretty often and use a scotchbrite pad and some hand cleaner with the pumice in it. If you clean them often enough, the scotcbrite pad and hand cleaner method works fine. There is no "magic" solution to removing the carbon build up.
what about dropping them in a pot of boiling oil for a spell..think so....
I use brake cleaner and a razor blade. Look like new.
averagesleder
Carb cleaner and a razor blade.
can I say tire cleaner and a razor blade..lol
