Was looking to get an opticool head gasket for my Viper. Just wondering which companies people have bought this from. I heard bad delivery rumors from the only one I can think of that has it.
			extremeviper
Yeah I checked their page. Prolly have to call I couldn't find it thnx
			Agpetro
I got mine from bender with no problem in three days.  Yea i know there is a thread going on this website about them.  Some people have very good luck with them and others haven't.
			TRUE BLUE SINCE 1980
I just bought one from Bender, Had it in a week from order to doorstep.
Did it all on line. NO PROBLEMS.
ottawaair
I got one from bender last season in about 4-5 days.
			journeyman
Has anyone compared compression before and after adding the opticool? Just curious if it is thicker than the stock headgasket.
		super1c
Super Moderator
journeyman said:Has anyone compared compression before and after adding the opticool? Just curious if it is thicker than the stock headgasket.
Odd that you mention that. My compression is down on all three of my vipers after changing to opticool. At first i thought i did somthing wrong when i first changed mine but it ran fine and it was down about 5 psi on each cylinder. So i thought maybe just my guage. Then when i checked my wifes and daughters post opticool exact same results. Down about 5 psi on each cylinder. So based on that i would say it is thicker, never dawned on me to check sise by side before installing. Indirectly this should also help with detonation i would think??? Not sure thinking out loud on that one. Chris
ottawaair
check the squish before & after install.  Hard to get an accurate thickness measurement on that style gasket, especially if it not compressed.  I removed the middle layer on my opticool last year.  .010" steel shim.  I believe they are .030" installed thickness.  Not posative on that tho.
			srxman06
Ordered one from bender on the 4th of Novemeber and still have not seen it
			snothrower
I ordered two on Monday 11/14 and received an e-mail that it shipped on Tuesday.  So I guess we'll see.
			srxman06
I had to call them and then they finally shipped it
			snothrower
Ordered 11/14 and received them today 11/17.  Can't beat it.  No problems.
			journeyman
super1c said:Odd that you mention that. My compression is down on all three of my vipers after changing to opticool. At first i thought i did somthing wrong when i first changed mine but it ran fine and it was down about 5 psi on each cylinder. So i thought maybe just my guage. Then when i checked my wifes and daughters post opticool exact same results. Down about 5 psi on each cylinder. So based on that i would say it is thicker, never dawned on me to check sise by side before installing. Indirectly this should also help with detonation i would think??? Not sure thinking out loud on that one. Chris
OK, that is what I was guessing. I think Bender designed this with the idea that people who used it would be running pipes. The compression does need to be dropped a bit on the center and mag side when running pipes anyways. When I ran the CPR's I used an aftermarket Speedwerx head with even compression around 135 psi per hole. My stocker normally runs high 120's on the clutch side and around 140 on the other two with the stock head gasket.
