Rear shock preload on 99 srx 700as
sb2.2z28
Reaction score
Points
ILL
I've searched and couldnt find a complete answer. What is the pleload supposed to be on the rear shocks? I am in the process of changing the track, and I wanted to set them to factory settings. Before I pulled the track off the rear was very stiff. I had to almost jump up and down to get it to move. About the only thing I could find doing a search said to set the spring from anything to zero preload to a few turns past zero preload. Currently the preload is almost maxed out on the shocks, with only about 3/8's of an inch of threads left showing toward the top side of the shock.
I weigh 170lbs. How much preload should I have?
