How´s the fit? Is it possible, do i have to make alot of mods to make it happen? I just thought that it´s easier to find a clutchkit to the v-max.....
			94-96 will bolt right on, you may have to realine the clutches, also you will need a longer and wider belt from the vmax, but some of the later exciters used the same belt.
			Great then i will use that secondary on my project sled! Thanx/d
			do you have the original primary on your sled? the vmax clutches are overdrive clutches.. i swapped over to 96 vmax 500 clutches on my last 87 exciter and was a night and day difference.. had ported cylinders and psi pipe as well.. i miss that sled!! i now have another nice low mile 87 exciter ..psi pipe, sx carbs and am looking for 96 clutches to put on this sled...
