nytrodave
I have a 97 700sx, it had hauck pipes and i put it back to stock. I and running 142.5 mains and 45 pilots needles are on the middle notch and fuel screws @1.5. It runs good, but will bog a bit off idle if i punch it. Over 4500 rpm it respond normally. Are the fuel screws too lean??
ryan2001sx600r
bog is usually too rich, hesitation is usually too lean.
			nytrodave
I t will sometimes back fire with the bog. If you feather up to clutch engaugement, no bog
			ryan2001sx600r
backfiring is caused by a lean condition as well.  Does it bog or hesitate?  They are different.
			If it idles great and everything else, just take your carbs off again, turn the fuel screws out another 1/4 turn, throw them back on and fire it up, let it warm up so the heat exchangers are getting warm to the touch (I do that part every ride). Put the throttle to the handle and hang on because your bog will be no more.
I never set the fuel screws to 1.5 anymore, I've usually been going to about 1 7/8.
EDIT: After rereading your original post and saying you have to feather up to clutch engagement, you might have a plugged pilot jet, but usually the sled will idle quite crappy if that was the case.
A couple of bucks
SXlover said:you have to feather up to clutch engagement, you might have a plugged pilot jet, but usually the sled will idle quite crappy if that was the case.
X2...
extremelyfastmax4
u do not run 45 piolt jets  they come stock with 47      i run 50 pilot on mine but its got tripple pipes
			nytrodave
Stock spec for 97 sx 700 is 45 pilot
			extremelyfastmax4 said:u do not run 45 piolt jets they come stock with 47 i run 50 pilot on mine but its got tripple pipes
I don't think Yamaha even makes a 47 pilot. Stock is in fact 45.
extremelyfastmax4
i would not post on this site if i did not know what i was talking about  i have a 700 that had 47 piolt and yes yami does have them
			extremelyfastmax4
also the vmax4s  run 47  piolt
			A couple of bucks
1997 Yamaha Sleds:
Models 97 700SX
Engine (cyl) 698 (3)
Carburetor Mikuni
Type * TM33x 3
Main Jet 1-145, 2/3-143.8
Clip Position 3
Pilot Jet 45
Float Height (mm) 13.3+/- 2
Fuel Screws 1.5
Pilot Air Jet 1
Idle RPM 1600 +/- 100
Engagement RPM 4000
Shift RPM 8300
Belt Type 8CH
Sheave Ctr to Ctr 268.5 mm
Sheave Offset 15 mm & 20mm ER
Clutch Weights (rivets) 8ch/10.3 & 13.3
Roller Type 15mm
Primary Spring W-S-W
Secondary Spring Green
Secondary Setting 60 deg
Helix Angle 45 deg
Gearing 23/40
Chain 70L
			Models 97 700SX
Carburetor Mikuni
Type * TM33x 3
Clip Position 3
Pilot Jet 45
Fuel Screws 1.5
Pilot Air Jet 1
Engagement RPM 4000
Shift RPM 8300
Belt Type 8CH
Roller Type 15mm
Helix Angle 45 deg
Gearing 23/40
Chain 70L
YAMMIEGOD3:16
WHATS YOUR ENGAGEMENT. YAMAHA MADE PILOTS WAY OVER 47. 3:16 (yammie tony)
			nytrodave
currently @4500
			nytrodave
I was running 50 pilots with the hauck pipes before I put it back to stock pipe
			extremelyfastmax4 said:also the vmax4s run 47 piolt
Al, Vmax4 750s run #47.5 stock
.................if all else fails, check your pulse (whatever you call them) lines from crankcase to fuel pump. Some times a small fracture in the line can cause a low end bog/stumble due to lack of pressure at the fuelpump, when the rpms build so does the pressure and the problem goes away. Having to 'feather up' the rpms is symptomatic of this also.
Good luck
			Good luck
							YAMMIEGOD3:16
YOUR CALLING IT A BOG SO I AM ASSUMING ITS RICH. IF ITS SLIGHT, YOU SHOULD BE ABLE TO CLEAN IT UP WITH AIR / FUEL SCREWS. TRYING CLOSING THEM UP 1/2 TURN. IF ALL FAILS, CHANGE YOUR NEEDLE POSITION, THAT WILL CURE IT. 3:16 (yammie tony)
							jvandeventer
anybody have sxr 700 tripple pipes they are willing to sell?
			A couple of bucks
http://www.totallyamaha.net/forums/showthread.php?t=83291jvandeventer said:anybody have sxr 700 tripple pipes they are willing to sell?
