coil question??
viper700t
NB
well i believe its my coil gone in the number one cylinder...when the sled is running and i braap the throutle some..it sounds like its only running 2...however when i pull the cap off the plug..it does change the sound of the motor however not the same amount as number 2 an 3 cylinders..when i pull those two, the motor dies like it should, but number 1 just changes the sound a bit but does not die the motor down..i did a compression test an its reading..#1-130 #2-135 #3-135...i also did a spark test an its still sparking however if anything the spark isnt as bright as #2 an #3..the carbs r spotless an set to stock settings...so im guessing its the coil..so i just want to get some opinions an see what other pp think..
no i did not move the coil..had no time lately but i migth try that..just thought i should get some opinions an see what other pp thought before i dug into it further
viper700t: I see your post in that other thread about unscrewing the plug caps. yes they unscrew. that's what super1c's post above is referring to. unscrew the cap on that coil, check the resistance, if good, trim back the plug wire and reinstall
ok so i just want to make sure i understand that...if i take the cap of an test the resistance an get 5KΩ then i just have to cut the wire back some an rescrew the cap back unto the wire..however if i dont get 5KΩ then its prob my coil...correct?
