Gitterdun1985
i have a vmax4 800 and i just had the carbs all cleaned and set. put them back on and there is still gas pouring out of the vent tub while its running. anybody have any ideas what could be wrong. thanks
Gitterdun1985 said:i have a vmax4 800 and i just had the carbs all cleaned and set. put them back on and there is still gas pouring out of the vent tub while its running. anybody have any ideas what could be wrong. thanks
Bluemonster2 said:one of your floats could be stuck down or you could need a new needle and seat in the carb that is leaking. When your carb bowl fills your float goes up when it gets to a certain point no more gas will flow. You could disassemble carbs again and lightly push the float up and blow through the hole where the gas line hooks up on that carb and if you cant blow through it when it is up then it is working.
You may have bent the tabs on the float to the point that it doesnt go up enough to stop gasflow. Check your float height while your in there good luck!![]()
