Im just curious if there is a company out there that will 780 your top end you send them from your sled. It just seems like it would be easier and a cheaper alternative then buying a complete kit in stock
and send you the bigger power valves?
mopar1rules
Tom, there sure are companies out there that will 780 your stock top end. Hauck, simons CPR, and Mrviper to name a few. Its not cheaper to send yours out, than to buy a used kit. Also, you won't get bigger power valves. They just machine your stock valves. Make me an offer on my kit. I'll iNclude 780 venom heads that are brand new and 35mm bored stock carbs.
Is it necessary to run 35MM carbs? Do you have 780 SRX heads? Im not sure what these go for used
I once had an issue with bored carbs!!!! LOL
Mine worked well with the stockers. More air will make more power, but it pulled plenty hard enough for what I was using it for. I was going to try a set of 38's, but never could bring myself to mess with it when it worked as well as it did with the stock carbs.
mopar sold me a set of carbs last spring that were clean and unmolested. The guy that had the sled before me had the carbs bored and whoever bored them, bored past the slides.
I seem to remember reading about some jetting issues you had with those
yea it idles and comes off idle much better now... The way I found out was by chasing my tail on pilot jets when I saw a noticeable gap between the slides and the carb bore
That carb rack is still sitting on the shelf for spare parts, about all its good for now
What are these kits worth?
IDK but I saw in SIMON CPR site they wanted over $3k for an 1100 kit on a thundercat
there is a 780 kit on ebay for 799, with everything
pm me the link
Macheater
If its the same one I saw, it was cylinders ONLY. No pistons or heads. $599 was the buy it now.
I was looking at that, its just cylinders nothing else for 599
doesnt get any cheaper then this sale price unless its used.
http://www.hauckpowersportsinc.com/pages/CustomCatalog/Product/1776
Macheater
Upon further review, there is also that semi-finished partial 980 Union Bay engine for a grand.
so is haucks kit a 780 or 800?
780
he used to make a real 800 kit that was 74mm but i dont believe he uses it anymore due to the thickness of the cylinders, too thin and pistons were extremely heavy design.
you can always call them and i am sure will tell you everything you need to know.
Thanks for that info.
Possibly to help save on cost, it would also work for me to do a top end swap with somebody that has a full kit. Mopar might be interested but ill let him tell me.
